Post by Jeff Kempton on Mar 6, 2013 22:25:50 GMT -4
hey jeff I am freshing up my 455 for my cuttless and removed all the insulition and soundeader hopeing to sqeeze in a s ss race between adra weekends and am going to pick criss chapmans brain on a index # It would be great to have you aboard Sam! Chris (or Ed, or Jack) can answer all your rules questions I'm sure, but feel free to contact me if there's anything else that you need help with!
Post by Jeremy on Mar 6, 2013 23:07:31 GMT -4
I was thinking of getting the intake side of my heads milled up to the rocker arm studs. I'm assuming it would then be legal next year. I'll hold off until next year to prevent any controversy.
But for real, bought some stuff to freshen stuff up. Also trying some stuff. Measuring stuff, weighing stuff. Still would like to get a couple more items to make my junk faster.
I went 1.467 in Greenfield with my tiny motor, but only went 11.20 due to lack of fuel for the air. I'd like to get closer to Kelly with his big engine.
Post by Jeff Kempton on Mar 7, 2013 0:10:32 GMT -4
I was thinking of getting the intake side of my heads milled up to the rocker arm studs. I'm assuming it would then be legal next year. I'll hold off until next year to prevent any controversy. I see that I'm not the only one following the Hemi head controversy on ClassRacer! LOL
Post by Kelly MacKay on Mar 7, 2013 11:04:11 GMT -4
I went 1.467 in Greenfield with my tiny motor, but only went 11.20 due to lack of fuel for the air. I'd like to get closer to Kelly with his big engine. with that big engine also comes 338 lbs
Post by mhowes on Mar 11, 2013 14:37:02 GMT -4
thats a lot of lead
Post by ChipperChapman1090 on Mar 11, 2013 19:32:22 GMT -4
Already a step ahead of you! lol
Post by Kelly MacKay on Mar 13, 2013 14:31:21 GMT -4
I went 1.467 in Greenfield with my tiny motor, but only went 11.20 due to lack of fuel for the air. I'd like to get closer to Kelly with his big engine. with big engine also comes 338 lbs well I can 110 lbs out and still run G weight (3305) IHRA. that will help with my 60.
Post by Jeremy on Mar 13, 2013 16:34:16 GMT -4
Yeah, it should help 60' for sure. May as well take advantage of the under-factored HP rating. The lesser weight difference would easily be made up by your big bore, short stroke engine with bigger valves, more valve lift and shaft mounted rockers. I'm in the wrong class. Should have picked a mid-70's Nova with a very soft IHRA HP rating. Oh, well. Everyone has fun. See you all in May.
Post by Kelly MacKay on Mar 13, 2013 18:40:37 GMT -4
Yeah, it should help 60' for sure. May as well take advantage of the under-factored HP rating. The lesser weight difference would easily be made up by your big bore, short stroke engine with bigger valves, more valve lift and shaft mounted rockers. I'm in the wrong class. Should have picked a mid-70's Nova with a very soft IHRA HP rating. Oh, well. Everyone has fun. See you all in May. where did that nova go you where driving. that would make a nice stocker
Post by Jeremy on Mar 13, 2013 20:14:11 GMT -4
where did that nova go you where driving. that would make a nice stocker Back to the owner. Hopefully we'll see it out this season. Has a little motor done up for it. I'll be interested to see how it compares to the 383 that was in it. Stocker would be cool too, especially now that 3 speeds are allowed in Powerglide only combos. 327 with a TH200 would be neat, although it would be another G/SA car. I guess a 4 speed would change that... Chris, looks like I have to get caught up then. Any photos of how to neatly attach the unaltered intake manifold once I machine the heads as shown below?
