Hi Don; there are other trucks in the Guide too; such as numerous Dodge products, but the GM ones are mostly what you've noted. However; if a truck that you like isn't in the NHRA Guide it may still have a home under the IHRA rules by running it in either the Stock GT or Crate Motor classes. For either of those the shipping weight of the truck is used as well as the NHRA HP rating (GT combos) or IHRA HP rating (Crate Motor) to determine the class and Index. I would say that nearly any GM, Ford, or Chrysler truck produced since 1980 (for Stock GT) or 1955 (for Crate Motor) can be used, but because engines have to be the same make as the truck I don't know of any imports that are feasible. I know you know where to find the IHRA Rulebook, but for the benefit of anyone else reading this here is the link:
www.bluetoad.com/publication/?i=186944&p=1The general definition and sub-classes for both Stock GT and Crate Motor Stock are listed below. For more details consult the rulebook.
Stock GT - Autos And Trucks Seven classes restricted to 1980 and newer body styles incorporating accepted engines from models years 1955 to 1979.
CLASS WEIGHT BREAKS FOR STICK AND AUTOMATIC:
S/GTA...................8.00 to 8.99
S/GTB ..................9.00 to 9.99
S/GTC ..................10.00 to 10.99
S/GTD ..................11.00 to 11.99
S/GTE...................12.00 to 12.99
S/GTF...................13.00 to 13.99
S/GTG ..................14.00 or more
Crate Motor Stock Thirteen classes reserved for 1955 and newer factory production automobiles, trucks and some sports cars using IHRA APPROVED factory type crate engines.
This includes 1/2 ton trucks, Rangers, Dakota’s, etc. Class weight breaks and indexes are the same for both stick and automatic.
DESIGNATIONS:
A/CM ...................6.00 to 6.49
B/CM ...................6.50 to 6.99
C/CM ...................7.00 to 7.49
D/CM ...................7.50 to 7.99
E/CM....................8.00 to 8.49
F/CM....................8.50 to 8.99
G/CM ...................9.00 to 9.49
H/CM ...................9.50 to 9.99
I/CM.....................10.00 to 10.49
J/CM....................10.50 to 10.99
K/CM ...................11.00 to 11.49
L/CM....................11.50 to 11.99
M/CM...................12.00 to 12.49
