Post by mirada on Apr 21, 2014 12:42:58 GMT -4
Well as you can tell by the pics from the car show, the NAPA AUTOPARTS ,HARPER FAMILY RACING , Super Stock Dodge Mirada has a new look for 2014.Since January we have been working hard to find that extra little bit of performance and also keeping with the NHRA Rule Book making sure the car complies,after not being to an NHRA event,since the late eighties, the car needed such upgrades as a locking Trans dipstick and tube,Transshield,fuel check valve,the car also has gotten STRANGE front brakes,Koni double adj rear shocks, front billet wheels,MSD upgrade,as well we have worked hard to scrape some access weight out and so far we have gotten close to one hundred pounds out between the firewall and rad support areas.that weight will be better behind the driver and will aid in weight transfer for sure.A huge thanks goes out to Jerimiah Lounsbury and the crew at JM Motorsports as well as Sam and my dad Frank for all your support!The past few months have been busy trying to come up with the funds for the trip and I would like to thank the following Sponsors for their help with this years racing season:
NAPA AUTO PARTS CANADA......... Ron Kelly Trucking.........Sussex N.B. JERON Trucking.............Bouctouche N.B. Driveline Truck and Trailer..Summerside P.E.I. Goguen Truck and Trailer....Moncton N.B. B.C. Auto Repair...........Salisbury N.B. Goggin signs and graphics...Salisbury N.B. INDY IMAGES...
With only a few weeks until Epping and garage time being hard to come by with so much on the go,ill do my best to keep you all up to date on our progress leading up to and including the race .STAY TUNED!!
Post by mirada on Apr 26, 2014 12:14:40 GMT -4
Lots done since last post, for starters we got the fuel check valve all installed, Trans removed and shield should be in Monday, rear ride height adjusted for the new shocks, and managed to find a little more weight!!And got my header teathers this week,so I'll get them put on also..oil change with some Royal Purple"available at NAPA autoparts!! And a fresh NAPA gold oil filter!! Lol..only a couple more week to prepare...
Post by mirada on May 5, 2014 9:53:47 GMT -4
OK!!!!! ... Ever bite off more than you can chew??..I figured I would take a look and some of the wiring on the car the last few days ......Well??...I ended up totally rewiring from front to back,not only did the thirty sumthing wiring look a little scary I knew for sure that it would be in my best interest to totally strip and replace all the old wires and run some new relays and fuse blocks,so after finishing that up last night and having the Trans gone over and adjusted tonights job will be to install that, with just over a week until we leave it looks like a lot of late nights...
Post by mirada on May 7, 2014 6:25:22 GMT -4
ok!!!....let me just say this TRANS SHIELDS SUCK!!.....This winter I am installing a removable transmission cover!!......Three hours fighting with that thing!!
Post by jkr on May 7, 2014 14:10:31 GMT -4
all that extra metal up against a stock floor pan must be a pain in the a$$. but if you remember uncle john's Omni the day the tourque left it's intended position behind the crank and bounced around for a while, as I did standing about 3 feet away, you will be happy it's there. if nothing else for peace of mind.
Post by mirada on May 8, 2014 14:47:35 GMT -4
all that extra metal up against a stock floor pan must be a pain in the a$$. but if you remember uncle john's Omni the day the tourque left it's intended position behind the crank and bounced around for a while, as I did standing about 3 feet away, you will be happy it's there. if nothing else for peace of mind. And didn't get even a drop of trans fluid on his fancey polester slacks or fancey boots!! LOL..
Post by mirada on May 9, 2014 15:07:46 GMT -4
Getting down to crunch time.the should be back on its wheels tonight, I have to finish the underside(header teathers,install driveshaft, change rearend oil, and give everything a once over...then tomorrow it will be tidy up wiring and hopefully fireup and valveset..hopefully....
Post by Jeff Kempton on May 10, 2014 11:58:29 GMT -4
Lots of hard work, but it'll be worth it when you race at Epping next weekend Alan. Best of Luck to you and any other racers making the trip!
Post by mirada on May 11, 2014 15:52:50 GMT -4
Thanks Jeff!! ...the car is back on its wheels...top up fluids and set valves tonight and fire up....
Post by mirada on May 13, 2014 18:52:24 GMT -4
On the Road!!! Almost to fredericton...finished up the car today at about 530 and met my ride at the Big Stop at 6:30 we loaded the car in his Stacker and hit the road. All the work has been work it for sure, I be keeping you all up to speed on our progress while we test and race the weekend, stay tuned!!!
