Post by POISON PINTO on Mar 13, 2012 13:15:44 GMT -4
Not sure what I got here. Looks like a Dana 44 or 60 from the removable back cover, but also has a removable third member like a 9" Ford. Was told it was a Chrysler 8.75, but they didn't have a removable back cover, and Dana's don't have a removable third member as far as I know.
Anyone know what I have here?
Post by Road Rage Racing on Mar 13, 2012 13:23:19 GMT -4
Toyota maybe?
Post by SS10 on Mar 13, 2012 15:55:16 GMT -4
Post some pics please .
Post by POISON PINTO on Mar 13, 2012 16:39:43 GMT -4
I'll take some pics when I get a chance. The car is at MacLean's Performance and Glenn said he's never seen one like it before. I just figured it was a Dana, but then recently learned they don't have a removable third member, so I don't know what the heck it is. Hope I don't break anything and need parts!!
Post by jpastuck on Mar 13, 2012 16:46:35 GMT -4
Where did you get it at? I remember seeing an 8 3/4 in a drag car in CB years ago where a dana cover was glued, welded, god knows what, to the back of the housing to make it look like a dana 60. Or possibly welded onto the back of the housing to use for gaining access to the center section... I never got a real close look at it.
Post by POISON PINTO on Mar 13, 2012 17:02:20 GMT -4
It came from CB. What kind of car was the one you seen. Might possibly be the same car!
Post by POISON PINTO on Mar 14, 2012 9:50:55 GMT -4
So that explains it, turns out it is a Chrysler 8 3/4 with a Dana cover WELDED on to it!! Least now I know what I have if I need parts!
Post by jkr on Mar 14, 2012 11:42:25 GMT -4
best rear carrier in 8 3/4 has 489 last 3 of the part # on the snout of the pinion. next best is 742 and last 741.
Post by POISON PINTO on Mar 14, 2012 12:26:56 GMT -4
Thanks Jeff, I'll check out which one I have.
Post by pugsmith360 on Mar 15, 2012 11:19:36 GMT -4
I did an 8 3/4 last year fot a 67 dart and the 742case actually has a bigger frt bearing than the 489case they both have the same rear bearing. the 489case has a collapsable spacer for preload and the742 uses shims for preload. 489 case is a little easier to come by.
