Post by mario428 on Feb 18, 2012 15:41:24 GMT -4
When I originally built the T-Bird I used this setup. Only problem was I ran out of adjustment and I have very little up travel of the strut. Tried a couple of different variations of the cup and brackets but could not get it where I wanted. Decided this was the winter I would fix a lot of the little problems the car had and the strut mount was one of them. So drew the front end setup in Solidworks and designed some brackets that held the top of the strut where I wanted it. Made up some holders to put the front wheel at ride height, some blocks under the frame to get it to ride height. Had laser cut and bent the brackets last weekend. This is my new setup Closeup of how I did the cup and bracket. I can change ride height by mounting this under or on top of the frame bracket. Or take another cup and weld a flange at a different point on the cup. Not an easy way to adjust ride height and travel but easy enough to do when the car is together in the spring. All welded up, just need to add a gusset and paint it.
Post by Todd Chase on Feb 18, 2012 15:55:28 GMT -4
Nice.
Who did your laser cutting?
Post by mario428 on Feb 18, 2012 17:00:52 GMT -4
Nice. Who did your laser cutting? My business has one, a small 2000W Amada. (oops 2000 Watts ) Between a CNC laser, CNC mill, manual lathe and a coupe of press brakes car parts are quite easy to make. ;D ;D ;D
Post by Todd Chase on Feb 18, 2012 17:31:30 GMT -4
No kidding. I'm just finishing up building a CNC plasma...
Post by Road Rage Racing on Feb 19, 2012 10:26:27 GMT -4
looks awesome
Post by mario428 on Feb 20, 2012 11:21:50 GMT -4
No kidding. I'm just finishing up building a CNC plasma... Buy one and fix it or build one from scratch? If from scratch we need at least 20 pics of all the details!!! ;D ;D ;D More would be better and at least a page or 2 describing how you did it. Well maybe that might be asking a bit much but would love to see some details and how well it cuts. Message board is kinda quiet so post it up!!!!
Post by Todd Chase on Feb 20, 2012 17:08:41 GMT -4
Build from scratch. I'm away right now, but I'll post some pics when i get back.
