Post by fabersp14 on Oct 4, 2011 20:46:59 GMT -4
Does anyone know what an empty GM big Block weighs (454 - 4 bolt nothing in it). I goggled it but no results. Thanks
Post by sixpack on Oct 5, 2011 15:35:48 GMT -4
Not sure how much it weighs........but if you drop it on your toes, it will make you say lots of bad words.
151A
Full Member
Post by 151A on Oct 5, 2011 16:31:14 GMT -4
empty GM small blocks weigh 170 lbs + or - depending on the casting, I would guess a big block to be about 30 lbs more Carl
Post by ShoeBoxRacer on Oct 5, 2011 17:17:03 GMT -4
If memory serves me Faber, they are around one eighty-five to one ninety-five lbs.
Post by fabersp14 on Oct 5, 2011 20:10:39 GMT -4
Thanks Carl, Bernie, I though it might be a little heavier than that , looking at a Merlin which is 270 before boring or an Aluminum at 140, so I guess with one I'll be adding some weight and the other a little lighter.
Faber
151A
Full Member
Post by 151A on Oct 5, 2011 21:02:18 GMT -4
I added 30 pounds with my Dart Little M . Carl
Post by Bad Influence on Oct 5, 2011 21:06:46 GMT -4
I do believe the BIG M is like 275-285 lbs
Post by Caperat on Oct 6, 2011 13:12:49 GMT -4
;D -- A bare 4.25 bore 396, 427 or 454 - 4 bolt block weighs about 218 lbs, give or take a pound or two.
Post by mario428 on Oct 10, 2011 8:25:00 GMT -4
Quote of the weekend when this thread came up "Don't know what it weighs but it moors my boat just fine!!!!!"
Post by BigT S/Pro 1968 on Oct 10, 2011 10:19:09 GMT -4
My reply for this is... I dont know how much it weighs.. But its gonna make a wicked gnome on my front lawn after what i did to it in Mirimachi !!
