Post by MercuryMan on May 31, 2012 22:52:30 GMT -4
Post by POISON PINTO on Jun 1, 2012 12:59:51 GMT -4
Nice looking mill!! I'm running the same block. 460's are torque monsters. Might be a dumb question, but is the benefit of the oil line connected to the two ports?
And might be my monitor, but the shade looks a bit too dark! ;D
Post by MercuryMan on Jun 1, 2012 14:05:14 GMT -4
I like the dark Ford blue, not much for the light blue. ;D...The oil line is just a paranoia thing....Some BBF builders recommend it due to poor oiling at the rear and some say it's not needed but I say for the little cost involved - why not. It used to be really popular to do with the Clevelands back in the day from what I've read.
What's your estimate on the HP seeing as your running a BBF???
468 cid, KB hyper flat tops, single valve relief, block is decked to .002" 10:1 compression Eagle H-beam rods D2 (PI) heads, ported, screw in studs, 3 angle valve job, (stock dimensions) Comp cam (34-243-5), .574/.580 lift, 234/244 @ .050" PRW stainless roller rockers, 1.7, 7/16" stud mount Melling HV oil pump, ARP pump shaft Cloyes double roller timing set MSD-6AL, MSD coil and wires, re-curved duraspark distributor PRW electric water pump Offy port-o-sonic single plane intake with a 1" spacer Holley 4150HP street carb Hooker super comps, 2" primaries with 3.5" collectors FRPP fox body oil pan swap kit C6 trans with a 3500-3800 stall, foot brake for now.
Post by POISON PINTO on Jun 1, 2012 14:46:56 GMT -4
Did you drill / tap the rear port? It's pretty small. That's where I take my pressure from, it's usually higher from the front port, so if I got good pressure at the back, the rest of the motor should be fine I would assume. Based on the info at 460ford.com, I would say you're in the territory of 450-500hp. Mine is a very similar build except I'm using ported aluminum CJ heads, Victor intake, more cam, and a 1050 Dominator. This is a pretty good HP reference chart for the 460. www.460ford.com/forum/showthread.php?t=119213
Post by MercuryMan on Jun 1, 2012 15:24:56 GMT -4
"ported aluminum CJ heads, Victor intake, more cam, and a 1050 Dominator. "....These will be my upgrades if I need/want more HP. ;D....Your's have a solid roller cam?. I didn't drill the rear larger, it's 1/4NPT. I could use aluminum heads, aluminum rad to take some weight off.
Post by ShoeBoxRacer on Jun 1, 2012 17:58:09 GMT -4
Nice job Stuart (even if it IS a Furd). Hope that it runs as good as it looks!!
Post by MercuryMan on Jun 1, 2012 18:03:55 GMT -4
Slowly getting there.
