Post by matthewclow on Dec 2, 2009 12:56:24 GMT -4
With a few unfortunate wrecks and fires this summer it has inspired me to spend the racecar budget this winter on safety upgrades. Sad that it took those events to get me going, but as long as it is done one way or another so be it.
-new a/n fitting steel braided fuel lines instead of hose clamps and rubber -upgraded u-bolt mounts for the batteries -new battery ground cable -new axles and wheel studs -new rubber on all 4 corners -full spool instead of a mini spool -new rad. hoses
I also challenge anyone with a safety issue to put it first.
Check something that you haven't in a good amount of time. Anywhere you can replace rubber with metal could be the difference.
